Engine What is a de-smogged 304 entail?
1979GabeCJ5
Alabama
‘79 CJ5
So, I have an AMC 304 (1979) so when I got it, it was partially plugged up, de-smogged, etc….
It has 3/8 MIP plugs on 3 places (2 removed currently) on the intake manifold. All 3 of the plugs had vacuum hose nipples (one had 3) on them that were rubber-cap plugged. Then there’s a weird cylindrical apparatus that says “AH”
What should be plugged? Is there a way to find the parts from the original vacuum/distributor “harness” that I’ve heard of? Should I just leave it plugged? I don’t think it’s a California vehicle.
Any guidance would be appreciated.
That looks like EGR and other EVAP component locations. I have a 79 AMC 304 at home I'll try to remember to get some pictures of the motor when I get home.
If it's running and you don't need it to pass emissions where you live then I wouldn't worry to much about it
That looks like EGR and other EVAP component locations. I have a 79 304 at home I'll try to remember to get some pictures of the motor when I get home.
So one of them is some kinda coolant sensor after some googling. Should that stay plugged?
Sorry for the bad pics
I'm going to plug off everything that I don't need
Yes
Okay, so I got this thing running but it’s running rough. I got my timing light I got marks on the crank, etc.
The problem: when I’m turning the motor by hand, when I reach TDC of the compression stroke, the dist. button is point directly at #1 but if I continue to turn the motor, I find that TDC of the EXHAUST stroke is not 180° from that of the TDC of compression.
Here’s two pics: the first is TDC of compression, the second is TDC of exhaust… bear in mind that I’m a novice at best with ignition timing.
Should TDC of Exhaust and TDC of intake/compression be 180° apart?
I’m having a big brain fart.
Engines vary wildly. I know the AMC 258 i6 / 4.2l really likes about 9⁰ before TDC the AMC 304 around 10-12⁰ before TDC. So if you're at TDC and right on cylinder 1 then that means your at 0⁰. You need advance your timing. Start by making sure that you have no vacuum leaks. Then start your engine and and rotate the distributor slowly until it idles better.
I tend to do this with the vacuum advance disconnected.
Engines vary wildly. I know the 4.2 really likes about 9⁰ before TDC the 304 around 10-12⁰ before TDC. So if you're at TDC and right on cylinder 1 then that means your at 0⁰. You need advance your timing. Start by making sure that you have no vacuum leaks. Then start your engine and and rotate the distributor slowly until it idles better.
Advance is counter clockwise correct?
To advance the timing on an AMC 304 , you must turn the distributor counter-clockwise. This is because turning the distributor housing in the direction opposite to the rotor's normal rotation advances the spark timing.
On my AMC 258 i6 / 4.2l CJ5 I removed the charcoal canister and circumvented the check and rollover valves with a pair of boat aluminum vents from Amazon.
Don't you get the smell of gas fumes with that solution? I would think just venting fumes from the tank into the air via those vents would create a gas smell, especially if enclosed in a shop or the garage. I'm all for eliminating the smog stuff if you can; but I don't want the gas smell in my shop. I kept the charcoal canister, relocated it, and attached the rollover check valve/vent to the canister, which still has a line back to the throttle body (I have EFI) to suck in those fumes. Here's a short entry about the option I chose: Tank vent option
    Best for votes
    on specific items
