"Which" 350 is the One?
Kilo19
Old Time Jeeper
- Media
- 15
- Priddy, TX
- 07 ford f-150 xl, auto, daily driver
98 chevy suburban, (family car)(SOLD)
2005 Ford Expedition
80 cj-5, body and frame
The new heads are way better than the camel bump ones and can be used on the old blocks. A buddy of mine has a 4bolt block with the new heads in a '67 RS. It's real nasty.
Hi all,
What have the folks who put in 350's used?
So I've heard and read that installing a Chevy Small Block 350 is the better way to upgrade from my old i6 to V8 power, and not going with the AMC 304.
However, when I called my local used engine shop nearby they asked 'Which 350 are you looking for?'
I was stunned because it hadn't occurred to me that they were different.
I'd like a carburetor simply because converting the jeep over to Fuel Injection seems to me to be as likely as organizing a 3 stage satellite launch from my garage. Its a giant, scary question mark in my head. I'll cross that hurtle if I must but based on the Shop's inventory it looks like I'm going Fuel Injection.
So, do I want a Pick up engine? Malibu? Police interceptor. . .. mmmmm. Impala? so on and so on.
Showing off my age! Lol , yep I'm 49 going on 50... I used to port my heads using a shop vac! Those were the days!
As for the 304 question, AMC heads flow great, the dog leg exhaust ports are great, unfortunately the 304 is limited by the valve size due to the bore, for a 5 liter engine it can be setup to scream (if you do the oiling mods).
The lates 70's truck blocks have the 4 bolts mains and a more desirable high tin percentage. these are considered stronger and hold a more consistant bore than other blocks. I used one from a 1978 truck for my build. I ran flat top forged pistons, Summit stage II con rods, Edelbrock aluminum heads, a decent cam and full MSD ignition system. I have a carb on it but the motor pulls like a freight train. I may end up with a fuel injection system on it for my other jeep build since I know it will handle any abuse I give it.
LtBest...............Before you set out on a rebuilt motor, you should price all the necessary parts and machine work needed to make it right. Also regarding used I'm not a big fan of sticking an unknown motor in anything and then having to pull it out at a later date............Once you have the rebuild cost in hand take a look at the GM crate motors programs available from GM.......cheap compared to some rebuilds , guaranteed and you can just about find anything performance & price wise.
And as far as those old Hump back casting GM heads those guys mentioned they are really showing off there age (LOL).........I think the first set came out around 1962 in a Corvette with a 327 inch FI motor & 2.02 Intake valves. Great stuff for the day not so now.
I think I will find this exceptionally good advice. Without a machine shop in my basement or a handful of friends with machine shops, we may head down the 'crate' route.I think I will find this exceptionally good advice. Without a machine shop in my basement or a handful of friends with machine shops, we may head down the 'crate' route.
