Diff Who's running what lockers and gears
Your also running an OD Transmission too if I remember correctly.Since my offroad time is really just light trails when deer or quail hunting, or camping with the wife, I didn't do any lockers. Got the Yukon Gear kit with a limited slip diff and 1-piece axles in the rear, as well as their carrier set in the front also. I'm running 4.54 gears with 35" tires.
Yes. That is correct. I have a 700R4 with Overdrive .Your also running an OD transmission too if I remember correctly.
What Transmission and tires are you running I was wondering about what gears to go with waiting on new tires to get here before I make that decision.3.73 and Detroit true tracs both ends, should be 4.10 but that is hind sight. Before I am informed yes I know the true tac is a gear driven LSD.
Since your running the true track I'm looking at have you had any issues with them. I mean when you need all 4 wheels spinning will all 4 grab and go. Not looking for a rock crawler or a mud machine. But when I lock in the front end I want to know I'm in 4wd with all 4 wheels pulling.3.73 and Detroit true tracs both ends, should be 4.10 but that is hind sight. Before I am informed yes I know the true tac is a gear driven LSD.
What motor and Transmission are you running and if your not running an OD transmission what's your rpm'sWhen i had the AMC20/D30 combo, i ran 4.56s on 33s (And later 35s) with ARBs front and rear.
Now with the Front D44 and rear 60, i'm running 4.56s with a front ARB and a rear OX running on air
AMC 258 i6 / 4.2l with an AX15.What motor and transmission are you running and if your not running an OD transmission what's your rpm's
they work! used them on the rocks in Moab, mud locally, dry, wet, they work and smooth! damm good in snow too.Since your running the true track I'm looking at have you had any issues with them. I mean when you need all 4 wheels spinning will all 4 grab and go. Not looking for a rock crawler or a mud machine. But when I lock in the front end I want to know I'm in 4wd with all 4 wheels pulling.
