will this work?
I would thing it would work. IF the dizzy cap is the same between the 2 motors I dont see why it would not. If they are different you could use the same set up but different cap. give it a try.
i think i would have to order parts from the U.S so want to get it right;)
It's a good upgrade but I would think you could get the parts in the UK. As your link in the 3rd post says;
All these parts are from a 1982 Ford F-150 Pick Up Truck With A 300 CID I-6 Engine
Other Ford strait 6's should have the same parts.
Once you get the bigger distributor cap you can get a CDI module if you want.
