Misc. Wondering What This Thing Is
will111t
Donator
Featured
Denver, Colorado
1973 CJ-5
1958 FC-170
That's a weird pressurized canister (looks like it has a capped schreder valve.) It goes into the cabin through the firewall (black hose.) Where does it connect and where is the red hose going?
It can't be emissions because it goes in the cabin.
I will investigate that tomorrow. I think it was stock, but I am not sure of that. This CJ sat a long time without being used much, but I can see where people worked on it here and there. Specifically, the wiring is all taped with black electrical tape. I think someone was in there messing with the wiring at some point. That’s what led me to this unit, whatever it is. But I will look tomorrow to try to determine what the black hose is doing and where the red hose goes. Maybe I will just surgically remove the whole thing and see what I can learn! Thanks
When you enlarge the pic, you can see that it is a charcoal canister for emissions. My first thought was it was a camping style propane canister.
In that case I will definitely remove it entirely. I had a feeling it might be associated with emissions but because I know very little about the AMC 258 i6 / 4.2l AMC engine I didn’t want to assume anything
It may be some sort of emissions canister but it is not stock. My 72 (which I bought in 76 from my neighbor) does not have it and an emissions tank would never be plumbed into the passenger compartment.
It's odd. The canister mount is bolted to the tub. Where does the line from the canister go to in the tub? Does the tub VIN match the frame VIN ? It also looks like you have a fuel tank vent ( the red hose, probably a "hard" hose) they are usually green.
It is the charcoal canister, partially capped off. You don't really want to remove it or your fuel tank won't vent. In earlier models (before they needed to burn fumes off in the engine) they were mounted in the left rear fender.
You can probably sell it, they are not made anymore, as far as I know. I had to rebuild mine.
There are 2 or 3 that can be used. I’m using a gm unit.
I am also using a GM unit (not brand name, but a cheaper after market copy). It's a part # 215-153 from Amazon. This crosses to a GM #17113148. I use a 3-port unit since I have EFI and no carb. With a carb bowl to vent, the stock one was a 4-port unit like the pic above shows.
Good morning all, I pulled the canister out of my trash, which will be picked up today. I will clean it, paint the canister mount, and re-install it. The vent for the fuel line is still in, and I will replace the lines to the distributor vacuum if I can find a place to do so (haven’t looked yet). There is a o place for a line labeled POV, which I know nothing about, and the Carb Bowl line is already capped off. Should I worry about any of these other than the fuel tank vent? Thank you very much indeed!
This is all very helpful. Thank you, bobjob. I’ll try to get the canister back to as stock as possible. As for the wiring, I removed all the electrical tape wound around it. Was that a factory finish, electrical tape wound around all the wiring? The wires themselves look fine so I’ll check everything for continuity and re-wrap them with something more suitable. Thanks again!
Yes, back then wiring was wrapped in Tape from the Factory. They stopped the Braided Cloth Sheath late 50's
