WTF? sealant will not cure!
kicknjeep
Old Time Jeeper
Lebanon,Tn
1999 TJ, 1976 CJ-5 2 seater
I used some copper gasket sealant on the oil pan and after 2 days it is still not setting and can still wipe it with my finger. set up the first time last week and had to scrape off when I replaced the rear main seal. what gives really do not want to pull the pan again, Wait a few more days because it's been wet and rainy out even I don't ever remember that being a factor before. :mad:
you should be able to use just black rtv.
Dale normally I would have but had some of the copper stuff and it cured just fine the first time I used it but this time it is acting like it will not? :confused:
And I really don't want to pull the pan again :mad:
I am by no means a professional at all. You said it was wet and rainy? Do you think the humidity could be doing something with it? I would try it again, and set it in a garage or somewhere away from mother nature for the time being.
yea was inside garage when i installed pan and come to find out the sealant had been frozen and I guess that will somehow cause it not to cure. Have pulled pan and am waiting for time to put pan and water pump back on.
    Best for votes
    on specific items
    Best for votes
    on specific items
