You know you own a CJ when...
When you wonder what what wipers larger than 5 inches look like.
When your kid keeps calling beepajeep on wranglers....you make cj flashcards so they can properly identify CJ5 ,CJ7 jeeps and not those imitations !
Sent from my DROID RAZR HD using Tapatalk 2
Your toolbox has Torx, SAE & Metric sockets. :bang:
When the local Chrysler Jeep dealer can't figure out why his wrangler rims won't fit on your "wrangler".
When you open the door and you have no dome light, You have no check engine light
Double post...
When you look under you CJ to check you fluids.
When you keep a flashlight in your CJ to check your speed/temp/etc at night.
Sent from my SAMSUNG-SGH-I317 using Tapatalk 4
When your sorry to hear that Sam5038 has a dome and check engine light in his jeep. Ooohh the miseries of modern day living.
when the people in the parts store shut off the computer and break out a book because its so old.
When you open up the hood and you can see the ground.
tune up involves feeler gauges, a screw driver, dwell tach, timing light and a ratchet,socket,& extension.
When you are told your CJ won't pass inspection because the horn doesn't work. Then you show them the KC switch under the dash that honks the horn, thanks to the PO's "customization".
When you find yourself standing at the parts counter trying to remember which parts are for your '75 and which parts are for the 82 Wagoneer engine you just installed .... ahhh lets see I need a clutch for a '75 Jeep CJ5 and '75 motor mounts and a fan clutch for a '82 Wagoneer, a fuel pump for a '75 AMC 304 V8 (they are different), motorcraft wires for an F-AMC 150 to fit on the D.U.I. Dist. and a GM ignition module ......... All the while the parts guy is looking at you like you lost your mind.
You cuss the forest service when they "Improve" the Road to your favorite camp site. :mad: Only erosion can improve a road
The parts kid keeps asking "What is the year, make, and model of the car your working on?" Doesn't he realize its irrelevant!!
I worked at orielly a year ago. I had this occasionally. They remembered me every time they came back. It was great
Luckily the guys are my local places are in there mid 20's -40's. When I explain what I have and what i'm doing they smile and nod.
