Build Thread 1966 CJ 6 build
:)I think there saying starter because that is where you would pick up the Hot lead from the Battery.........Just wire it back the way it was I think your alternator has a large 12 gage Red wire that goes to the battery now does it not?............because that loom is generic just disregard any of those extra wires that have no use in your system.
:D:D:D:D
Yes, there is a wire from the output post to the starter too, red one.
The book says find the wire, it's white, that connects the voltage regulator to the starter relay and slice it in.
I think that wire will get set aside for now.
Thanks Tarry.
So clearly the pictures are up-side down for you guys, strange. Took them with the iPhone as usual and posted. Funny, it looks fine here on the iphone. I will have to see if I can switch those.
Just looked at it on the desktop and that is strange. I am using a new version of TapaTalk. I guess that is one of the advanced features.
Ok, in the course of typing this and trying to upload again I see that TapaTalk has updated their software, around the image upload specifically.
At the moment it will not even let me upload.
Or I was drunk and holding it upside down.
So getting closer on the wiring. Did some simple test and looks like it is checking out so I fire it up! Starts up after a bit of cranking but it has been sitting a while. Sounds good, no sparks, that's good right !
So shut off the key... Still running! Pulled the coil wire to get it to shut off so I have a little more testing to go!
Troy Cantrell
Build thread - '66 CJ6 :
http://www.jeep-cj.com/forums/showthread.php?t=15075
Troy,
:)Looks good.............keep it up the finish line is near!
:D:D:D:D
Getting close, got one last issue with windshield wipers on the wiring and then the harness is done. Still a bunch I would like to do but should be in decent shape do drive.
I still don't know how trustworthy it is, hasn't left me stranded yet but haven't driven it much. Not sure if I will get it out tomorrow, suppose to be about 109 here.
I need to get some pics of the hood back on too.
Troy--
CJ Build thread- http://www.jeep-cj.com/forums/f98/1966-cj-6-build-15075/
Looks like your getting the upper hand one the beast. I noticed that you still have the old heater setup. I have talked with a few others and come to the conclusion that those old heaters don't work worth a dam. I replaced mine with a box heater from Maradyne M# 5000 heater, puts out 12000 btu's. bolts to the fire wall inside the cab up under the dash so no fear of losing leg room. Just a thought anyway great job. Kadar
Thanks, getting close to a good summer stopping point.
I took your advice and check out those heaters and then took Terry's advice and kept the old one too. So now I have the factory heater and that same Maradyne, we sure didn't need it today! Christ on a crutch it was blazing today and the heat coming off the floor too, thought we might melt.
Over all the jeep ran well though, no real issues. Some dieseling and a slight backfire when going down hill and letting the engine hold us back. Didn't do it every time though. Only did a few trails around the lake as it was so bloody hot.
Troy Cantrell
On the last run the Jeep seemed to be running a bit rich, gas smell in exhaust, I pulled all the plugs and found the in great shape, all clean and dry. I checked gap and reinstalled and then checked timing.
Timing was set right at TDC so moved it to 5• BTDC. Will get a good test run in as soon as I replace the seal on Transfer Case .
The plugs had a very shallow reach, not sure if that is normal or not I will have to check that out.
Troy Cantrell
Dropped the drive line last night so I can replace the rear seal on Transfer Case . I have this nice arch of oil on the bottom of the rig right in line with the yoke where it sprays gear oil out.
Anyone know the size of the nut in the center? Looks to be 1 1/8 but not sure. I will pickup a set of larger sockets today on the way home as I didn't have anything that big.
Troy Cantrell
Picked up a set of bearing race and seal drivers and put things back together. I just need to pressure wash under there and take it for a test drive.
