Build Thread 1966 CJ 6 build
Looks nice but makes the air cleaner look like it needs some love. :D
Oh yeah, it is looking pitiful at the moment isn't it.
It looks like you have your heaters plumbed in series. Mine had "Y's" in the feed/return lines to each core. I think I'll use your method when I put mine back together. I'm glad you posted that pic.
I thought about doing it that way but thought this was cleaner. Might not produce as much heat though.
The "Y" setup seemed to put out pretty descent heat (for a Jeep ;)) it was December in Minn. Temp in the teens with a drafty soft top and it got fairly warm in the cab. Maybe I'll end up trying both ways.
Thanks.
Man there are a lot of wires on that harness. I think mine had like a dozen total wires and now everything wires through the fuse block, which the old CJs don't have, so everything is double and then there are a lot of circuits I don't have. Like a dome light, no dome lights is this CJ.
I am not looking forward to that part of my rebuild!!! Keep it up and you will be done before you know it:chug:
This makes two of us. Keep at it and you will be wondering what you used to do with all the free time!
Looking great BTW...:popcorn::popcorn::chug:
i like your tie strap idea....never would of thought of that.
how big was the heat shrink tubing?
Used the 1/2" on those, it was the 3/4"clamp. Use something to hold the metal though, it gets warm.
Troy...............sounds like that loom assumes you either have a Generator or and early Alternator with an external regulator.........
My regulator is external but only 3 wires. One is ground, one I think is called field, the other is on the post next to the output post but none go to the starter. I think that last one goes to the coil from that post but not looking at it at the moment.
:)I think there saying starter because that is where you would pick up the Hot lead from the Battery.........Just wire it back the way it was I think your alternator has a large 12 gage Red wire that goes to the battery now does it not?............because that loom is generic just disregard any of those extra wires that have no use in your system.
:D:D:D:D
