1970 225 Starter or something more
KcSolomon
Pensacola, FL
1970 Jeep CJ5, V6, Manual
Yesterday when I got in my jeep to drive to work it would not turn over. I checked the battery and it was outputting 12.5 volts so I tapped the starter a few times and it started right up. Same thing happened when I left the office for lunch and again when I was going home. So on the way home I stopped by Advance and picked up a starter. Didn't have a chance to change it out last night. This morning when I tried to start it up it turned and turn but would not start. I pulled the air filter off and could see fuel squirting into the carb. Started to check the plug wires around the distributor and knocked a #14 wire (hot when the key is on) that runs to the cap off by accident. In all fairness it was very loose. I pulled the cap off and saw that there are 2 prongs that it could go back on. I put a new connector on the end of the wire and went with the one that was cleanest(closest to the outside).
My questions are;
1. Did I put the wire back on the wright prong and should something be on the other one?
2. Should I go ahead and change my starter or check something else first?
Thanks,
KC
Might consider taking the old starter in to your FLAPS and have it checked...
    Best for votes
    on specific items
