Brakes 1975 Cj5 E-Brake Removal From Backing Plate Tips
curly
Featured
12
Arkansas
1975 CJ5 258
1. is the stud pattern and spacing correct? flip it backwards and check if it will go on
2. the shoes don't look centered in the photos.
3. maybe the adjuster on the bottom is too big (long) ... check the size with the old one
best of luck, you are that || close to success.
I think you’re right about #2. Looks like the shoes are off centered. I adjusted it and now it’s barely going on but still not lining up. And #1 was a great idea, flipped it over and it’s supposed to fit on there. I’ve taken off the shoes 2-3 times and put them back on but I still can’t seem to get it on there. May take some more effort than I thought.
I’d like to avoid arcing the shoes but we’ll see. Been busy the last week so hopefully Monday or Tuesday I can get some time to try this some more. The shoes seem secure for the most part so not sure how much more I can get them centered or closer.
Appreciate the advice man, definitely helped me out a lot.
$45.00
  22.5%
