Build Thread 1975 CJ6 on the skinny...
danc9
Clarksville, IN
1975 CJ 6, 258 I6, T-14, Dana 20, Dana 30, Dana 44
1975 CJ6 with AMC 258 i6 / 4.2l I6, T-18 , Dana 20 , Dana 30 , and Dana 44 . This is not what I wanted at first, but after studying it I thought it would be fun. I have lots of time, and not a lot of money, so going will be slow at first. That should be OK seeing how long it's going to take me to repair this tub! The real damage so far is the rear frame is gone! The Dana 44 rear end is missing the breather....., need to know if I can tap something in to replace it? And of course RUST.
I know, if it aint' got rust, it aint' a JEEP!
  • As of now what I want to do is repair all the rust to the best of my ability.
  • Replace seals that are bad.
  • Replace all the bushings
  • Full brake job.
  • Clean and paint every thing.
7 April 2012
Worked on the seat brackets today....
Till next time.....DAN
8/9 April 2012
Well the exhaust flange had a 10/32 bolt holding the front. It had been broke off and drilled out to put the smaller bolt in......
Drilled it out, re-tapped the threads and put it back together. The head on the other hand...the two top center bolts would not come out! I cut them off and worked on the manifold. Later trying to remove the two bolts........%$&?@#.....but I won!
It all works out in the end, DAN
Sometime it doesnt all go as planned and things slow you down. But that CJ6 is way to cool to leave go by the wayside. Keep pluggin away. I know Im watching. :chug:
I think your work in inspirational. You have far more crud to deal with than my 6 has, but it is such a cool ride. Cant wait to see it finished.
Are you using an arc welder or wire-feed for all that FAB welding?:chug
This is my old faithful. I've been burning with this thing for many years. Flux core.
DAN
10 April 2012
Worked again on getting every thing off and out so I can pull the tub. It took longer to clean out the shed than it did to get it ready! Welded the differential lever, man it feels tight now. Cut the under seat tool box out, with the help of a spot weld drill bit. Don't know how you would do it without one....
The tub is ready to be pulled....
DAN
Re: 10 April 2012
I like how that tool box came out... I might have to consider doing that. Thanks for the pics, looks like a decent tub you've got to work with.
Not that it needs to be said but - CJ6 's are cool!
11 April 2012
Got the tub off today. Worked on the passenger side....
DAN
12 April 2012
Worked on the cross members on the tub. Hard to rebuild some thing that is not there! I found a build of another 75 CJ6 and fortunately he had some great images of the cross members......
I didn't get to finish them, but I feel like I put a dent in them!
DAN​
13 April 2012
Got the cross members done. Replaced a corner in the floor behind the drivers seat. Started rebuilding the bed floor supports.......
DAN​
Keep up the great work Dan. :) Shes coming along and looking alot more sturdy. :chug:
14 April 2012
Got up early to get a full day in. Got the tub over on the other side, set out all my tools and welder, and it started to rain. Put every thing away, worked on one of my minibikes,
sun came out and I set up my tools again. It started to rain......I didn't get any thing done today!
DAN​
16 April 2012
Got the passengers side floor in, and a little more work on the bed reinforcement.
DAN​
17 April 2012
Worked on the bed first. Got the reinforcement done and the panel set in. The body is actually rigid now! Started on the passenger side shell work.....
Man this is fun!!!
DAN​
Looks good Dan. That tub is really coming along. Glad your enjoying it , I am also. :chug:
18 April 2012
I got the under seat tool box back in today. I also worked on a few spots on the shell......
The PO knocked the holes down, filled them with bondo...my shell will be a bit wavy, but it will be all steel!
DAN​
19 April 2012
Finished the welding on the passenger side. Good thing, I ran out of wire, third pound!
I am the slowest body man in the world! Getting a little better at it, but not much.....
This morning I got to thinking about the ignition. When I looked on line, every thing I saw had two wires from the distributor. I double checked mine and sure enough, one wire.....the PO has dropped a pointed distributor in there. Best I can make out, around 72 or earlier.....
DAN​
23 April 2012
Worked on wire wheeling a bunch of little stuff over the week end. I just spray bombed them black.........today I wire wheeled and primed the fire wall.....
guess I got to get it back up on it's side again.
DAN
