Build Thread 1979 CJ7 Rapid restore - 1 Year build from tired and rusty to all go and some show..
Apparently they are terrible in the mud but decent on the pavement and gravel/snow.. something tells me they won't get used as much as the Super SwampersThat’s a different tread design.
Fired up the engine over the weekend and well @%$%#@ and.. leaking head gasketcoming out the last water channel I suspect, no fluid crossover and its running nice but off she comes again.. luckily I bought an entire gasket set about a year ago so I have 2 more chances to get it right..
This was my first time using copper spray, maybe I was a little light on the coat?
None of the head bolts on AMC pass through water channels. I am using the felpro gasket with the steel shim which I was told by the builder to coat both sides of the shim, this is how is was assembled initially. The felpro's I have also state using a sealant is required on their steel side which mates with the steel shimYou using steel shim head gasket? I assume so since you mentioned copper spray, i personally like the felpro gaskets, On my Dodge motors some head bolts are open to the water jacket and will leak if you dont use sealer on the threads i cant remember if the AMC motors ate open
Looks great, is your gear box a variable ratio box?Woohoo, out of the garage for a test drive close to home. So far so good. This new steering setup feels super tight.. and slow, almost too slow. I may ditch the HD dampener for comparison but almost feels like a lack of pressure.View attachment 100823
Thanks, took a couple more quick runs and kicked up some mud on it finally.. felt like christening a ship hahaLooks great, is your gear box a variable ratio box?
It does feel more "in control" and far less wander on the hard stuff when I lay into the pedal.. I have had 2 CJ's with power steering now and this new build still feels off, I said above no resistance but it feels like its a bit more resistance to turn than it should, like its running at half powerA wider lock to lock steer range is safer and can save you from an overcorrection mishap. Four turns on the steering wheel is typical. But the lack of “road feel” is the price to pay with most power assisted steering set ups.
I never really thought of that until you commented and I looked at the picture again. I have an electric fuel pump from a quad that I use to pull fuel out of the tank and it would work perfect for this. Only thing I can think of is once you have used it out on the trail you have to store the pump/hose somewhere and there is always a little gas left in it, inside the cab would stink.. I would need a small external storage box.. going to think more about this one some more! Thanks for the comment!!Siphon it right into the main tank. Nice.
