1979 CJ7 w/ automatic 4 wheel drive question
jjump
Pittsburgh
CJ7
All 76-79 CJ7 with automatics have the QuadraTrac Transfer Case . It's a full time case that may or may not have a low range. If it has a low range, then the shifter will be on the side of the Transmission tunnel near the driver's seat.
The Quadratec is full time, so it contains some type of differential in the t-case to allow for driving on the pavement. The emergency drive switch in the glove box locks the t-case differential, so it powers front and rear equally (like a regular t-case in 4hi). Typically, there are no lockout hubs on the front axle. If there are, there may have been a part time installed. I don't know exactly how the part time kit works, but it allows for 2wd and 4wd operation similar to a regular t-case. Lockout hubs are then used on the front axle and I believe the emergency drive switch is used for the 2wd/4wd switch.
I don't have any personal experience with the quadratrac, but from what I've read, the biggest issues are lack of low range on some models, and stretching chains with lack of quality replacements.
$35.00
  17.5%
