1980 304CID leaky thermo housing - WHAT?
DHugg
- Media
- 46
- Resources
- 1
- MS Gulf Coast
- '80 CJ7 304AMC crate with 8KMiles: MC2100 - AMC20 rear w/Superiors - Dana30 front - TF999 - Dana300TC - 35x12.5's - Tilt steer column - Flaming Rvr EZ-Steer Shaft - AGR Super Pump - AGR Super Box II - RockyRidge HD Brace - New home-designed digital TEMP - GAS - OILPR - CALIBRATE gauges.
Picked up a leak, tiny dribble, from the thermostat housing. Remove, scrape, sand, polish, new gasket and sealant specifically for thermo housings.
Same dribble again. The fluid IS antifreeze and it drips from the lower edge of the front axle gearbox. Engine is cool (185 thermostat holds it steady) and no liquid anywhere else.
Absolutely HATE the idea of two bolts only in a circular aluminum housing to try to clamp a circle.
Does anyone have the thermostat housing sealing procedural equivalent of a thermonuclear bomb? Doing the same drill over again to try for a different outcome is the definition of idiocy.
