Wiring 1980 CJ-7 Turn Signal dash switch.
RepoDave724
I have a 1980 CJ7 . I've replaced the turn signal switch in the column only to have the lever strip out again.
I have a 3 position switch. Left, Center, Right. Center is off and the left or right have normally open and normally closed contacts. I want to wire the in dash switch to operate my turn signals and eliminate the turn signal lever altogether. I'm OK with leaving the guts in the steering column but i'm tired of the lever just flopping around. I already know that the self cancel feature won't work. I am aware that this isn't recommended. This is the way that I would like to do it. I just need some insight on the wiring to make this work.
Thought?
Dave
Thought?
Dave
