Build Thread 1986 CJ7 Build
-Clocked the t-case up another hole in the adapter ring. Looks better and sits about level with the bottom of the transmission now. The mount for the shifters fits tight against the transmission now too. There’s a little pocket there in the passenger side of the NP435 that looks like it’s made for that.
-I’m leaning towards bending just the inboard shifter a bit outward. Overall, they look pretty good.
Nice! With my AX15 conversion I had to clock it to the lowest position to clear the Transmission . This also gave the front drive shaft more clearance from the bell housing. I did have to trim the tub floor so the shifters would fit. Great build
Nice work. Those JB twin sticks are great. Only thing I disliked was their boot. I used a Stronghold shift boot and that worked great and dressed it up.
Thanks Belizean. Not very often that we don't encounter a problem or two with this many new/changed things. I'm knocking on wood now, but I'm sure an adjustment or two is coming.
The Strongwell Boots are nice how they combine the 3 shifters under 1 bezel. However, I'm doubting it'd work in this application because of how far forward the NP435 shifter is, compared to the OEM T-176 .
Maybe you could do me a favor and measure your boot from top to bottom?
-Now, it's time for an emissions test before I can re-register the Jeep's tags. This is getting really old having to do this test, which is required every 2 years in the County I live in here in CO. I pleaded with the DMV lady the other day, saying I only put about 200 miles a year on the Jeep, so my Jeep's yearly emissions are probably less than my lawn mower. No luck with an exemption, except that if I buy "Collectors" plates, I only have to do emissions tests every 5 years. Will think about that option.
I’m glad I don’t have to contend with those emissions regulations. Not sure mine would pass. I would go for the every 5 years plan.
Thanks for measuring, Belizian. I think it's too short overall though. I'd have to go the custom route & I'll look at their website and see.
Otherwise, the new upper boot for the Transmission is supposed to arrive today and I'll test fit it to see what it looks like. It's likely that I'll have to overlap the boots at their mounting flanges because of how close they'll be together. We'll see tonight.
Turned out well. I actually like it non rhino-ed.
Yup. Coolant leaks suck!
Fortunately, this one was fairly easy to fix.
Pressurized at the cap and as suspected, crack at upper neck.
Clean, heat, flux, heat, solder. Then pressure test.
Did this a couple times until I observed no bubbles under pressure.
I’m not a radiator guy and much respect for the skills required. Around here, hard to find a single radiator guy.
Yeah I know of no Radiator guys around here anymore. There are a couple of shops that sell them, installing new but don’t fix them.
Heck, most "SHOPS" do not even know when to use acid core or rosin core solder... 😥
Probably with the cost of labor it’s just cost effective to toss another Chinee radiator in most cars.
Affirmative.
I think there are only 2 rad shops in the Denver area. Environmental/chemical issues and throw away plastic radiators are what I’m told is causing their demise.
$20.00
  10.0%
