258 / 4.2L 5/8" x 3/4" heater hose
jdcaples
Old Time Jeeper
Seattle, WA
J0M93ECxxxx
J - Jeep
0 - Year 1980
M - 1980: 4-speed Manual
93 -Inches of Wheelbase?
E - 4150# GVW
C - 6 Cyl, 258 CID, 2 Bbl
Dana 300, SR-4, stock and rusting; I'm the fourth owner.
It's not only the water pump outlet, but the thermostat housing. Both are 3/4". I just learned this mixed logic recently while doing my engine re-do. I'm going to run with the plastic adaptors for now, but I have a pair that I'll be making from some copper........just in case the plastic fails.
Some of these little things (like the mixing of sizes) just defy logic.
On mine, the heater core is 3/4 as is either the thermostat housing or the water pump outlet (I forget) is 5/8ths.
So 3 out of four hose connection/end-points are 3/4" while one is 5/8ths.
I think the water pump is the 5/8ths.
-Jon
Yeah, I forgot to mention that on mine, both of the engine connections are 3/4"........while the core is 5/8". I learned this when running the 5/8" hose from the core to the water pump.......I was like......"Two sizes? Really?"
Could it be there are multiple scenarios for different years. Mine has the water cooled intake so I have 6 ports, which I believe 4 of the 6 are 5/8" and the other two are 3/4". I know I pulled off two diff. size hoses but not sure off hand how they were. I do know that I bought new GY HighMiler hose in 5/8" and they fit on both the water pump and thermostat ports, plus the front intake port. I'd have to dbl. check the rest of the ports to be sure. But I have heard of this 5/8 to 3/4 issue.
I always go with a metal adapter if I need one.... I am more curious about the story behind your hand injury.....
It's embarrassing and a long story.
Suffice it to say that I shouldn't have used the base of my thumb and palm as a hammer banging against the end of a short ratchet when there was a perfectly good 24 inch breaker bar not 15' away.
I tore some tissue and angered some nerves. I don't know how long it's been, but today's the first time picking up a wrench didn't feel like root canal below the wrist.
-Jon
