258 build
powdertwoplanker
Good day to all, I just pick up a used AMC 258 i6 / 4.2l (AMC 258 i6 / 4.2l ) block. Well I got a few other things with it but its all going to get tore down an rebuild. I been researching other builds an haven't found anyone that's used the F.A.S.T. fuel injection system yet.
http://www.fuelairspark.com/fas/ez-...ystem-master-kit-w-inline-fuel-pump-kithtml/]
If i missed a post about it sorry. Please point me in the right direction an if you can give me some search pointers, cause I tried many different combo's
So the build plan is to do the minimum amount of machining, change the cam an switch to the 4.0L head. I would like to do a header of some sort an maybe a different intake. I still have a lot of research to do on all of this so if you have any input it would be much appreciated. I like the fast system because it doesn't call for a different or another computer. It also seems like a little easier to work with and on. I know i could just get a donor jeep with the head an injection stuff on it an have all the parts but it seems like a lot more work. Cheaper yes, but also more things to go wrong. I also don't have to worry about emissions as by the time it goes in to my 1985 CJ7 , it should be exempt
So if you have any thoughts, experience or places to do some research please send them my way
Sent from my ASUS Transformer Pad TF700T using Tapatalk
