258 Valve Cover Oil Leak- Solution.
Captainlance
Long Island, NY
1984 CJ7
After considerable investigation, I've found a simple fix. FELPRO makes a gasket that is thick cork, with a rubber covering. Works like a dream. The part number is VS50244R
Hope this helps someone.
Lance
Make sure your PCV valve is working correctly, and that it is the correct one for your engine.
And the PCV valve is installed towards the radiator with the breather towards the firewall.
I've always used weather stripping adhesive to glue a cork gasket TO the valve cover. Use clothes pins to hold the cork in place while it dries OVERNIGHT. Wet the cork with oil then install the valve cover. The oil makes the cork swell and seal. Use a hand held nut driver to tighten the valve cover bolts. Easy does it......
slomo
