4.0 Distributor in 258/232?
dagr8tim
Columbus
75 CJ5, 232, T14, Dana 20, Dana 30, Dana 44
97 XJ, 4.0, AW4, 231J, Dana 30, C8.25
I've been reading and cannot find a specific answer. Can you use a 4.0 dist in a AMC 232 i6 /AMC 258 i6 / 4.2l ?
I've got a spare 4.0 sitting in the garage and think it would make a great upgrade to what's currently in the AMC 232 i6 .
Will it fit? Yes. Will it work? no. The 4.0 utilizes electronic spark advance run by the computer. Since I am assuming you are running a carb you will need a distributor that has vacuum advance.
Not even with say an MSD ignition box?
If the the msd ignition module can somehow control timing then maybe but the 4.0 has a computer control module for the fuel injection that uses sensors to know when to advance/retard the spark. If the msd mudule can control spark advance then sure it could work but I don't see how it could without the engine sensors.
You could always swap in that 4.0
