Build Thread Starting from the frame 1977 CJ5
Poly Kits for Anything.....
They Squeak !!
Even More when it gets Cooler to Cold Outside.......
Yep, they become harder when the chill happens. That is why I am a true rubber fan...
There was no exhaust gasket between the head and the manifold just pack with soot and the surfaces on the manifold are pitted bad
I like a Guinness once in a while. Cold.
Disassemble, clean, lightly grease, reassemble.
Lay everything out on a rag in the order that you remove it. Take pictures too.
Those old hubs are pretty simple. But they get gummed up over time, especially if not turned/exercised.
There's probably more info on this site too, if you do a search.
Just because it's not tailored for a 77 CJ5 does not mean you can't use a CJ8 kit. You will just have some leftover items.
I know I have body mount locations shown here for different CJ models. I'm looking now...
$70.00
  35.0%
