'75 CJ5: D300, T5 info requested
DieselJeep
Mansfield, OH
1974 CJ5, Isuzu 1.8L 4FB1 Diesel
Hello everyone,
I am converting a '75 CJ5 to a small diesel. I am using a T-5 and a Dana 300 . I believe the CJ has a 4" lift. The springs have taller than stock shackles and much more arch to the springs.
I have hit a few snags:
Does the T5 bolt to the crossmember directly, with possible a thick piece of rubber between? What is the stock setup, and how is it isolated?
I have 3 possible locations for the Transmission crossmember. With the T5 and D300, and the Jeep was bought with no drivetrain, I have no idea how it goes together properly for the stock driveshafts I have. Even searches and the Haynes manual is not helping.
Thanks in advance (if I can get actual help here. My requests for dimensions for stock tub wheel arches doesn't seem to be worth anyone's time even after a week of patience) !
The T-5 Dana 300 combo might be too long for your swap. The 4 inch lift will severally hurt your driveshaft angles. The dana 300s behind the t5 also had long output shaft. The d300s cj5s from 1980-83 came with short output shafts behind four speeds only. The diesel being hopefully a four cylinder might mitigate the length if you can push the motor forward enough. You have a lot more work than worrying about the skid plate. Think the entire swap through and consider a lower spring shackle combo to start.
That diesel will tear that T-5 apart.
It depends. The mercedes om617 will be a good fit for a T-5 .
