76 quadra-track hooked to gm 400 auto
Just about any, with a new adapter, which requires removing the GM Turbo 400 output shaft, which comes out through the front.
Kevin I am doing the same thing also. I got rid of the QuadraTrac . I have found if you are going to keep the same front and rear axles the Dana spicer T-18 will work. The T 18 front and rear yokes are also offset to the passenger side. You will also need an adapter kit. I went to Novak conversions they have every thing you need to make it happen. I hope everything goes well for you. Keep on touch, we can probably help each other out.
    Best for votes
    on specific items
