79’ Jeep CJ7 304 Engine Not Straight!!
haymaker101
whately Ma
'79 Golden Eagle 304 Quadratec
Just in case..check the Transmission mounting...had an issue with mine when I first bolted it in..couldn’t get the configuration right and it off set everything...simple fix when I found it...had me scratching my head for a day..
Thanks for the idea of checking the transferase mount. I will do that tomorrow. Are there different mounting locations possible? Do my engine mounts look correct? Are they in the right frame hole configurations? Thanks in advance
I know you wouldn’t have thought so..but on my 86..it was not as obvious as you would think..had to googlefoo to eventually find a pic of the right deal...I’m not saying that’s it ..but that’s exactly how mine sat before I realized it was wrong..if I can get a pic I will...
Start checking to be sure the frame is 'square'.
I’m not sure what the problem is but I think I’m just going to live with it and find a way to make my headers work. Thanks for the ideas guys
