Build Thread 79 CJ7 "They’re coming to take me away aha"
Looking good. I know exactly how you feel about the getting down on your knees situation. Hopefully some more after some more healing all will be good for both of us. ;) Boy for under $300 I wonder if it's worth me getting new cable or a whole new winch? :cool:
Looks great folks! Personally, if I had to winch myself about every time I went out I might consider a Warn, but in any other case (including my own) a Badlands is perfect. We have a few where I work mounted on trailers and don't have any problem with them.
Pete: I guess that the warranty just expired, on us that is.:D The bodies are just wearing out! New pains every day. The winch is currently on sale at HF for $294.78 using coupon code 64793915
007: After having to use a come along to get my son's Acura MDX up on the car hauler after the radiator blew out on the road last week, we are going to order another one for the trailer. Glad to know they work out for that.
Nice work it should work great :notworthy:
Well done!
Thanks everyone!:) Still a bit more work to do on it, but rapidly coming to completion.
No plans to move now that I am retired. Just the thought of trying to move a lifetime of accumulated stuff is enough to make me want go back to work! :eek: Besides, We finally have our shop set up to do the things we want to do until we degrade to mere couch potatoes!
I was just wondering if we'd meet in another state by chance. Vicki and I have plans to move to Virginia in another year or 2
That's awesome. Looks fantastic!
My wife has family both in Virginia, and West Virginia. Wisconsin may not be the off roaders dream, because every attempt at creating an off road park gets shot down, but everything else here is just great! We hope to get out East sometime in the next few years to do some wheeling.:D:jeeplove:
Something to consider:
I've been thinking about your tire rack, something has been bothering me about it but couldn't quite put my finger on it. You've attached the bottom to the bumper and the top to the body. It occurs to me that the bumper is attached to the frame which moves more or less on it's own and the top is on the relatively thin sheet metal of the body. If you look at factory tire racks they are either ALL on the body or all on the bumper. I fear that frame flex just might transmit to the upper attaching point causing it to tear the heck out of the body's sheet metal.
:agree:
Hmmm, Good point Hedge. There are a few things that are not visible in the pics though. First, I originally designed the tire rack without the upper tie in's. Problem is, when I hung the tire, I could see that there was going to be a lot of give bouncing down the trails which would eventually lead to more give and eventual failure.
Although the carrier is pretty solid, the bearings are somewhat loose inside the housings allowing for some flex. As far as how the body is mounted in relationship to the frame, there are the usual body mounts throughout, however at the roll pan, there are an additional 3 mounts besides the factory mounting points between the body and the bumper that although rubber, are quite rigid not allowing the rear of the body to flex a whole lot.
The original carrier that I made, which did not swing out, but was completely rigid, mounted the same way. Lower mount connected to the bumper, and the upper to the body. Never had a flex issue. As a matter of fact, the upper mounts are attached to an area where the PO filled in with bondo, and even the bondo did not crack with all the off road bumps and bangs.
Thanks for the observance though, catches like this really help me with future designs.
If you find it does pull at the sheet metal put some steel plate on the inside of the tub where the carrier mounts to strengthen it and disperse the tension.
I think your bearing issue is why folks including myself use tapered wheel bearings for this type of hinge. If tight there is no bearing sloppiness there. At that point the spare tire movement is from metal flex not a loose bearing.
I put a lot of steel in my tire carrier with only one truly solid attaching point, the tapered bearing, and one latching point. When closed the latching point carries some weight, but the bearing carries the major part of the load. I actually do fear that it won't hold all the weight. Itself + 5 gallons of water + 5 gallons of fuel + the tire hanging off the rear. We will see how long mine lasts. I'd like to do just as you have done by using a second mounting point.
It was a common issue with the OEM Jeep CJ carrier to tear the body from off road shake'n.
If you ever watch a CJ in front of you on a twisty/rocky trail. You will be very surprised at how much the frame and body really move separate of each other.
HH-You have about 74 lbs just in liquids, not counting the cans weight. How much does the spare tire and what ever else weigh?
Should you be think'n about a 2nd support point? Sure would hate to see the carrier fall off and cause a accident.
