Build Thread 79 CJ7 "They’re coming to take me away aha"
man thats some progress I love building engines looks like you having a blast there
Most fun I have had in a long time! I just wish that I didn't keep finding little things that are needed as we go along. It seems that we spend more time waiting for UPS to come down the driveway than actually making progress! :bang:
Good team work!
Looking good!
Transfer Case gears aside the FSJ 20 is a better case to keep because of the U shaped shift pattern. Unlike the CJ case you will have independent drive axles without having to deal with the interlock pills.
That's awesome Bass! I might send you my stainless pipe. Mine is a tad too thick. Won't sit it intake and won't take cap...
Is it exactly 1.5" OD? If it is, put it in the freezer for an hour or so. When you take it out, wipe off the condensation that will form and coat the part that goes into the manifold with a light film of motor oil. I used a seal driver and the BFH and it went right in. If it is at all over 1.5" OD, don't force it, you could damage the aluminum manifold!
Mine is 1 1/2 on the nose. My manifold opening is 1 7/16.
Man that's looking sweet
The whole set up cost me around $16 including the heim for the fork push rod. The heim joins are from eBay, and seem to be of good quality for a clutch set up.
ECON 1/2 x 1/2-20 FEMALE RH ROD ENDS HEIM JOINTS HEIMS | eBay
ECON 3/8 x 3/8-24 FEMALE RH ROD ENDS HEIM JOINTS HEIMS | eBay
I got the jam nuts at the local hardware store for around $1.
I am lucky from the standpoint that there is a steel supplier a few miles from my house that will sell any steel by the foot for about 20% over what a full length per foot pricing would be. Pretty sweet deal if you don't need a 20' or 24' piece.
If you have a securely mounted bench vice, you could probably make the bends with that if you don't have an actual parts bender.
That does seem like a pretty tight fit. I do not recall what my exact manifold dimension was, but I called Edelbrock, and they told me that the manifold was bored for a 1.5" OD tube. I have never seen a 1 7/16" fill tube. Most of them are 1 1/4" or 1 1/2".
Mr. Base - Many years ago I made my own clutch rod similar to yours, the difference was I just cut off the "L" at the ends and threaded the existing rod. As I remember (it was 1986) the rod was very hard and resisted threading, it was a great modification. Your work is always inspirational.
It is od that the oil filler is only swadged in place. My 360's pipe was loose, probably from the junk doing a sloppy job of pulling the engine. As it turned out the bottom was tweaked a little. After fussing with it a lot the tweaked part was cut off. With a block of wood and a BFH it was reset, although about 1" shorter than stock it hasn't moved since. My thought is, if the stock pipe won't come out carefully apply a punch and a BFH to knock it out. Then cut off the slightly damaged portion and reset it in place as out of necessity I did. ......come to think of it though, my manifold is the factory cast iron item, aluminum might not take well to a well used BFH.
Thanks, this is going on the Colorado To-do list! I'm hoping that I can use my vice to make the bends. If not Ill find a shop to make them.
So when you fab your own driveshafts this way, is balance ever an issue?
$150.00
  75.0%
