Build Thread 82 CJ7 frame swap & lift build
rbagley
- Kalamazoo, MI
- 82 CJ7 w/258 I6 (Weber 38/38) de-smogged
5 speed manual BorgWarner trans
Dana 300 transfer case
Dana 30 front. AMC 20 w/lunchbox locker
I posted this question separately mid-February and am again thankful for the help of guys I have never met. I heard back within 2 days with the info I needed and then with a great diagram that is sure to help others.
I got a response back from mtnwhlr and elwood blues that I wanted to include in my build thread.
Where do the (air, temp & defrost) dash pull cables go? Specifically, which one goes to which lever on the plastic blower assembly under the dash? ........it had been a couple of years since I busted the old cables out. As far as the new cables go, two of them are the same length and the third one is longer........Thanks in advance! This is one of a handful of things I never completed once the Jeep was dune-able.
on your pic the temp is the one on the left and the defrost is the one on the right and the air is up above and will be the longer cable. Hope this helps.
this may help too
