    Thank you for your support!
Sweet one last one for the road
Sent from my backyard using Tapatalk
Been almost a week.... you holdin out on us???
Sent from my gas grille using Tapatalk
Lol.... nope. Daughter bought a new car today and I had Some youth at the house for D now this weekend, hope to have the caliper adapters welded on this week
Sent from my throneusing Tapatalk
Got the caliper adapters finished, ... finally, hope to have them welded to the axle today
Well I did not get my brakes finished just quite yet, one day I might confess to how I did not measure the Transfer Case output correctly but not today lol.... so I did get the rear axle re welded and am ready to start welding the caliper brackets in place but that is going to have to wait a few more days as I have to borrow a welder, I sold my old welder when I went to Afghanistan with the intention of buying a new one on my way home.... funny how that didn’t work out
Sneak preview.........
Very nice...... are you using compressed air to activate the piston to get the mounting bracket in exactly the right spot?
And I knew your new garage was big, but holy :dung:, dude........ a forklift???
Sent from my "library" using Tapatalk
Sshhh our little secret on the fork lift and yes I have compressed air actuating the piston to locate it
Ok hopefully I won’t have to open this monster for awhile
I haven’t even made it out of the garage and I am going to have to buy more u bolts for the axle grrr
So close....... now I need to work on closing brake system up and bleeding it
Sweet work. I also like your Tapatalk sign offs
Lol thx, was busy today and forgot to change a few, I got the idea from shum8
Sent from work using Tapatalk
LOL - Nice brake work, man - that’s a beefy looking axle.
Sent telepathically using Tapatalk
well I got the brake lines hooked up and the driveshaft hooked up as well started filling the master cylinder and pumping on the brakes and I remembered that I have not taken care of the residual pressure valve yet, so I need to get that out of the way
Got some more work done, the track bar is coming together faster than I thought it might. Trying to decide how I want the front attachment to look on the end of the tubes
Steady progress looking good
Well I had some time at the old house today so I picked up some of my Mopar memorabilia
I plan to slowly clean them up and rebuild them
Sent from my old ciapractor using Tapatalk
More better
Sent from my garage using Tapatalk
3 weeks, 2 days, 21 hours, 47 minutes, 49 seconds
