Well, I used some anti seize to do my tooth contact patch on the front axle and I still don’t like the way it looks and my 2 year was napping so I couldn’t take it apart to reshim the pinion
So on to the bell housing, got a jack stand under the oil pan got the bellhousing off to use as a pattern to make a new engine dust shield got it close to size and had to start dinner
Lets see the pattern on your front ring and pinion.
some type of sheet metal ?
Looks good so far.....
And yeah - Where’s the pattern???
My 1971 Dodge FSM shows the gear patterns and how to shim it up and down and of course I can’t find that manual anywhere and the Jeep FSM doesn’t have a diagram of it
There ya go
Sent from my couch using Tapatalk
Looks like you need some more pinion depth.
Yeah - they need a bit of a tweak..... you’re close!!
Gonna add 10k in the morning and see what it looks like, gotta get that done before we go to nanny’s house
Cold air, shum8, whatcha think ?
I’m tempted to put another 5k on the pinion to see if I can get it perfect
Better - but still looks too close to the tooth edge to me.......
It’s strange to me that one side is in the center and the other side is on the edge, I don’t remember this much difference with the other axles I’ve assembled the patterns where usually closer together
Mine was like this as well - one was centered and the other was not quite. But neither was on the edge like that. Too much pressure on the edge will cause it to chip
What's your backlash like? Are you rotating it with any load?
Sent from my SAMSUNG-SM-G891A using Tapatalk
Using my hand as load and my backlash is .0005
I would decrease backlash ( ie move the carrier/ring gear closer to the pinion ) before you add anymore to the pinion.
I would decrease backlash before you add anymore to the pinion.
Aren’t we supposed to have between .0006- .001 backlash?
Oh i didnt see what your backlash was set at. I would add another 5k to the pinion see how it looks
Hopefully I can get a few minutes to try it tonight before the kids go to bed
Just a double check, are the extra 0s a typo? Should be .006-.01.
Lol oh ya I was trying to remember how many zeros there was on the dial from the couch
