Build Thread 83 CJ7 its time to get it done
some type of sheet metal ?
Looks good so far.....
And yeah - Where’s the pattern???
Looks like you need some more pinion depth.
Yeah - they need a bit of a tweak..... you’re close!!
Gonna add 10k in the morning and see what it looks like, gotta get that done before we go to nanny’s house
I’m tempted to put another 5k on the pinion to see if I can get it perfect
Better - but still looks too close to the tooth edge to me.......
It’s strange to me that one side is in the center and the other side is on the edge, I don’t remember this much difference with the other axles I’ve assembled the patterns where usually closer together
Mine was like this as well - one was centered and the other was not quite. But neither was on the edge like that. Too much pressure on the edge will cause it to chip
What's your backlash like? Are you rotating it with any load?
Sent from my SAMSUNG-SM-G891A using Tapatalk
Using my hand as load and my backlash is .0005
I would decrease backlash ( ie move the carrier/ring gear closer to the pinion ) before you add anymore to the pinion.
I would decrease backlash before you add anymore to the pinion.
Aren’t we supposed to have between .0006- .001 backlash?
Oh i didnt see what your backlash was set at. I would add another 5k to the pinion see how it looks
Hopefully I can get a few minutes to try it tonight before the kids go to bed
Just a double check, are the extra 0s a typo? Should be .006-.01.
Lol oh ya I was trying to remember how many zeros there was on the dial from the couch
$125.00
  62.5%
