The only safe place for the jack is to somehow mount it on the inside. My first mount was across the back. I backed into a tree and bent it. Next was across the inner fender wells. It was always in the way when getting stuff out of the back. Now I have it across my front bumper and I know that someday I'll bend it again. A friend had his mounted upright on his tire carrier. He snagged it on a tree branch and ripped his tire carrier off. I've seen a few mounted on the cowl. Not sure how I like that or if it's in the way when opening the hood all the way. That may be my next try.
I have been thinking about mounting mine vertically on the roll bar behind the driver seat... not sure if it will fit yet
I have an AMC 360 pump, pulley, and bracket from project86
And I just ordered a steering box for a 98 Dodge Durango which is a Saginaw same as the CJs with the same hose fittings
It will be ready to pick up tomorrow
Ok - Once again you probly just spent some of my cash......... At least all I would have to replace would be the steering box......
Sent from just this side of consciousness- Time to hit the rack.
Lol and now I start seeing how other people have their hi lifts mounted
Hopefully to be mounted this weekend
I’m anxious to see how it goes.......
Sent from right here.......
Im not much on the hood mounting. Mainly as the rain and dew would leave rusty water on the hood. Maybe as a temporary trip mount it would work but not full time. The side or back mount would be a better option
If it stops raining any this weekend I’m going to at least try to look at where I can mount it permanently and hopefully dry
I mounted a hi lift on the front bumper of my son's jeep. Made my own brackets for it. My reasoning was if he was gonna be in a crash the more steel/protection up front the better.
Let’s get to the most important question, when is the Wrangler decal coming off! Lol.
And that’s some impressive hauling there, I think our state DOT departments would lose their mind on that set up here in communist MA. They love to tweet out pics of the vehicles they’re ticketing for unsafe load transportation.
Hahaha
Grrr
Steering box swap on hold til I get the right u joint from Borgeson
The Durango box has the small .720 input and the Jeep has the large .8 input
And now to re install the old steering box.......
At least the littles are having fun
It’s getting hard to keep the Hulk from coming out grrr
Grrr
That's odd. When I installed the durango box in my rig, It was a direct fit.
Do you remember what year model you bought your box for?
My steering shaft definitely has the large input
And oriellys who I bought the box from shows each box has the small input
Do you remember what year you bought it for?
I don't. It was quite a while ago. I bought the box used and it replaced a YJ box. I had somehow thought that all boxes with power steering had the same input.
Just did a little web search and the 98/99 Durango is supposed to be a direct fit.
Thanks that’s the one I bought, summit racing has the correct u joint in stock in Arlington
Well this might be interesting I think I might have carpal tunnel in my right hand,America is going bananas, my job is going bananas this is going to be interesting
Hmmmm.... Use your left hand, change what you can and don’t sweat the rest, work harder than the other guys, and have a cold beer...... [emoji481]
