Build Thread 85 CJ7 Rebuild, Labor of Love
Ultrunner
If I remember...isn’t that where the exhaust attaches..
Could be, it’s been so long since I ripped all that out
Ya about that nut on the frame......
I know that the sway bar mount bolts go into rivnuts..... why on earth they used them we will never know, your going to have to grind the heads off the bolts get the bracket off and figure out how you want to replace the rivnuts....... all of mine spun in the holes so I had to grind the heads off so that’s how I know and still haven’t fixed them lol![]()
Today marked a turning point. I have removed everything from the frame and am ready to send it off to be blasted. It seemed like getting to this point was never going to end with the endless amount of rusty nuts and bolts that would seem to just appear.
Finally got the tub off and beginning to remove everything mounted to the frame.
Brake line, fuel line and steering removal.
Had to cut these leaf spring bolts, no amount of force would budge them.
Finally the frame is on stands and axles removed.
Any idea how to get all the rusty bits out of the inside of the frame?
Masscj7, good point. Maybe I’ll just replace the rear cross member fully, I’ve got to fix the body mounts anyway, and with it off just get all thatout.
Yeah, exciting times coming. Have to move into the garage.
If you get one, check out Chief Wahoo out of Kansas. His are way nicer than most aftermarket ones. Beefier, will size to either CJ or YJ tubs and good price, if I remember around $125.
I’m thinking once I get the brackets removed (sway bar and steering gear) I’ll clean up the frame and just have the brackets welded in place. When the hell am I ever going to strip this down like this again? Prolly never.
Lol even if you do strip it down you don’t really need to pull the sway bar mounts off anyway
Nice work! I really enjoyed rebuilding my knuckles and spindles. If you use that press for axle shaft u joints, be careful you don’t bend your yoke ears in. Mine were so frozen that didn’t realize I bent them in till I was trying to put the new u joints in and they didn’t fit.
