Air filter question
Air filter question
dtrojcak
Victoria, TX
1978 CJ7 4.2l manual trans
The hole is for a the valve cover breather. you should have two grommets on the valve cover one PVC and the other a breather run a hose from the air cleaner to the breather spot on the valve cover. you can also run a mini filter instead of the hose and plug the air filter hole. IMO this is a cleaner look,i have pics of my air filter and mini filter if you need ideas. good luck.:chug:
    Best for votes
    on specific items
