amc 20 pinion yoke is stuck
bobt
pennsylvania
1978 CJ-5 258ci/T150-3spd
Im trying to remove the yoke on an AMC20 rear to change the seal and the yoke will not come off. Tried using a 6" gear puller and bent it, tried a steering wheel puller and bent it too, tried beating it with a 5# hammer and that didn't work. Splines on pinion and yoke don't look twisted or bent Any other options I could try?
Try heating it.
The pinion yoke will not come off? After removing the pinion nut it should be a slip fit.
If the yoke does not slide off with minimal force you have a serious problem...
Get a lighter hammer, like about 32 ounces, and give the yolk a solid hit. Don't wail on it, but hit, turn 180*, hit, turn 180*, hit, and so forth and see if that helps.
This may be a stupid question, but you did remove the pinion nut?
Soak with PB Blaster, get a good puller on with tension (air gun) and heat it evenly around and give it some love with small sledge.:bang:
Using a puller while applying a bit of heat to the yoke has always worked for me. Put it under pressure with the puller.....heat it up a bit, then give it a good rap with a hammer.
Thanks for all the replies. I tried what Les suggested. Heat while using a puller and then beating it off. It took several blows until it came off. I saw no issues with the teeth on the yoke and pinion. I did clean both and they are still really snug. Should I worry about any other issues because of that? Should I try a new yoke?
TCase Dana 20
$125.00
  62.5%
