AMC 20 Seal Leak
jeepjunk4
- New York
- 82 scrambler sbc turbo 350 dana 44 locked
85? cj7 302 ford auto 4wd hardware glass tub
Ok, so I did a solid axle swap in my 85 last year, and the right rear started leaking gear oil not long after I did it, I only drive it local and plow with it so I've just kept an eye on it. Now that summer is almost here I need to fix it. The way I see it is the inner seal is probably in wrong or nicked, cause that is really the only thing that keeps the oil back, right?? And why is it, that I have read to silicone the outer axle seal before installing it?? It seems to me that if the gear oil is getting past the inner seal, the outer isn't really gonna make a difference is it?? What am I not getting??
