AMC 20 Welding tubes
driver007
Canada
1981 cj5 304 v8, 300 Dana,model 30 Dana and model 20 AMC rear end
What seems to be working for welding the tubes to the diff housing? Four 1" welds. I have welded lots of mild but very little nodular cast. Pre heat to what temperature use a nickel rod like a 309 and post heat? Hate to mess up the only rear end I have. How do you check for sagg in the tubes. Would sagg really matter. Over time the rear end gets lots of stresses. Or do I just leave well enough alone? I do not plan on hard core driving just want to fix up while I change out the gears.
:)Yep ......skip welding the housing is correct............Pre-heat and post heat. Pretty hard to get it over a few hundred degrees. I would heat the weld zone up with a nice rose bud. Take your time and heat it evenly.
The post heat .......IE;letting it cool down slowly is the most important.........cover it with a welding blanket.........and Hi nickel rod is best for arc and 309 stainless works well using a TIG method.
Might be hard to do correctly if it is still in the vehicle.
Lots of those in service that have not been welded , just depends on your level of driving.
:D:D:D:D
I had mine welded with (3) 1 1/4"-1 1/2" welds at third points around the perimeter.
