AMC 401 conversion help
mharakal
- Northampton, Pa
- 82 cj7,amc 401, dana t18 trans with d20 transfer case. full vortex spray on liner in tub and outside body.
So after replacing the belts, there is still a loud squealing sound, i've checked and rechecked the belt tension. i drove it yesterday for alittle after the squealing went away, parked in for a bout two hours, and when i went to start it the squealing was back. I'm stumped, any ideas? Also I noticed a couple noises when in first gear. alittle bit of popping, slight rubbing, but once i get into second, third, etc, there are no noises. also getting out of first gear into second is pretty damn tricky. pardon my simple questions, but this is my first go with owning a jeep, and let alone one with such a beastly engine, Transmission , etc. is it normal for first to be noisy, ,and is there a trick to shifting the t-18s? thanks
