AMC20 axle
86 will be a WT.
The axle should be a Dana 44 , but I have seen several '20s' on that yr also.
Is the diff cover round? If yes, it's a '20'.
The trac-loc AMC used is a joke, look for a power loc.
It's definitely round... so, wide Trac eh?.... thank you.
Sent from my SM-G925V using Tapatalk
What do you mean by "the Limited slip went out"?
Do you have stock 2 piece axle or 1 piece shafts?
OP-That sounds more like you 'spun' a hub on the OEM axle set-up.
Yup, that's what makes them two piece. Make sure that the woodruff key is still holding them together.
The 2-piece axle came to be, thx to the AMC bean-counters.
The 2-piece axle has a well known history for failure. My first(and last)failure, was about 3 yr after I bought my '7'.
I fix'd the whole rear end issue with a Currie built, Ford 9" axle assembly. Not an issue since.:D
