Build Thread Amp'd
Build Thread Amp'd
Rj67cj6
Houma, Louisiana
97' Wrangler-given to son
79' CJ5-sold, but not forgotten
05' LJ-DD, but will be 4 son#2
67' CJ6-work in progress
Looks like a great project. Please keep the pictures coming. Good Luck.
Looks to be in very good shape
vin matches the model, year, and engine
appears to be a late 67, possibly August.
let me apologize for the pictures. They are out of order, but I will try to keep them check from here on out.
So I am back to some pictures of the body and finally really getting a good look at what ive bought. its amazing how much you don't notice or see when your looking at buying it.
Im pretty satisfied with what I see, but then again it is covered in layers and layers of olive drab. There is some diamond plate cut outs bolted to the passenger and driver side floor boards. Um yeah, usually a good sign someone is wanting to cover something up.
I will not be putting the roll bar back on since I believe, and someone correct me if im wrong, they did not come with them for that year, 1967. I do know that this one was added later. It is bolted to the rear fender wells and the floor with no backing, very flimsy.
Finally! Some paint other than olive drab, which leaves me both happy and sad. Happy since my plans were to paint the jeep back to its original color, but sad because I don't care for the color Red on vehicles.
After some research on the year and colors used. This must be Presidents Red.
I'll have to rethink my plans and options, but first ill have to get rid of all this olive drab. It's all over. They painted the axles, shocks, brake lines, headlight bezels, rubber shift boots, leaf springs, ect............................!
Well as mentioned before, my plans are to restore this jeep back to original or as close as possible. So with that being said, I've been searching for some original rims and tire replacement. It currently has some 31X11.5 BFGoodrich, which are some nice tires but very over sized for the stock Ross steering which I believe is a huge cause for the horrible handling. So after so time looking I was able to locate some original Kaiser Haynes rims with 15x4.5 stamped on them. Looking very narrow, but I was assured by the seller that the rims came off a late 50's Willys Wagon and he was running some 235x75R15 radial tires. I've already decided to go with some Firestone Destination A/T tires 215x75R15, which would bring me close to the original tire size for the jeep without paying a butt load.
best thing about the rims is they were cheap and he has five of them. Did a little more research on them after I got them home and started cleaning them up. These rims are riveted, not welded, which I was told could prevent me from up grading the brakes from 10" to 11" drums. That up grade wasn't in the plan, however, after getting a closer look of that tiny master cylinder, it could be an option.
Nice job those look great. Those are the same tires I run on my wifes Cherokee and I love them.
You can tell there old by the riveted centers. Not sure what year they went to welding them .Does the rim have safety bead ? Those where probably used with tube type tires. If they hold air "no harm no foul"
Nice project. mike :)
Time to take lots and lots of pictures. This is my second jeep that I will have done. My first one was a 79' CJ5. And if I learned anything it's that you can never take enough pictures for
Reference.
Looks like a great project.Everything looks pretty stock.You may want to take a close look at the engine.Might just be aftermarket valve covers or something but I don't think there original Dauntless Buick 225 V6 parts.
:)mike
$45.00
  22.5%
