Another twin stick question
ken98k
North Pole, Alaska
{1980 cj-5, 258, t-176, d300 amc20 rear, D30}{1974 cj-5, 304, T-15, D20, D30 front, D44 rear}{1973 cj-5, 304, t-98,D20, amc20, D30}
{1990 yj 2.5L i-4 AX-5 NP231 Dana 30 front Dana 35c rear}
1996 XJ Cherokee 4.0 HO
{2000 silverado}
{1979 Cadillac Sedan DeVille}
So I just bought the JB Fab twin stick for my Dana 20 .
Am I going to have to remove the "pills" to be able to shift to 2 low?
Am I going to have to disassemble the Transfer Case to remove the Pills?
I wrote the following answering in another thread, it is more applicable here:
Without additional surgery you should have:
2 wheel high, the left lever back and the right in neutral
2 wheel low, the left lever forward and the right lever in neutral
4 wheel high with the left lever back and the right back lever in 4 wheel high
4 wheel low with the left lever forward and the right lever forward in 4 wheel low
Basically:
If the right lever is back the left lever can ONLY be back, it WON'T go forward, except for neutral.
If the left lever is forward the right lever can ONLY be forward, it WON'T go back, except for neutral.
Further surgery on the Transfer Case will allow options like front wheel only in high or low. With other disastrous options available. This has been covered several times and I'm too tired right now to rewrite about those.
With the pills removed you gain options like front wheels in high or low with the rear wheels in neutral.
