Auto choke wire
Auto choke wire
flashwillys
wisconsin
1979 cj-7
Does anyone have a 1979 CJ7 with a stock working choke? Id so where does the wire come from to make it work. thanks
I believe there is a oil temp switch located next to the oil pressure switch on the side of the block. this should give you give you 12V with a warm engine.
I have never had a working electric choke so I will not claim to be expert on this one.:D
Does anyone have a 1979 cj7 with a stock working choke? Id so where does the wire come from to make it work. thanks
I had mine hooked thru the oil pressure switch, so when the engine was running, the choke got 12V.
