Axle fab pricing
Axle fab pricing
j6824
Central Virginia
'78 CJ5, 258, D30, AMC 20, 3.54, T150, 33s, Sniper EFI, 4"BDS, 1" M.O.R.E. body, Team Rush, MDS 6A, BDO tie rod flip, Adams shafts, Speedhut gauges, 8274
I'm sure this has been discussed before, but I didn't have much luck in a search...
Just wondering what I can expect ballpark-wise for labor for an axle narrowing and r&p setup with locker (don't have the KSAs, tools or experience to DIY). I was able to find some pricing on Dutchman's site for narrowing...about $AMC 150 , $100 to attach new ends. I've reached out to several local shops and can't even get a response.
I'm looking to upgrade to a rear 60 with mollies and an cabled Ox. I have a housing...I was just curious if it's even possible to get into one for less than $3-4K, soup to nuts, when it's all said and done...that's what it would run for a completed bolt-in assembly. If that answer is no, then I might as well go that route.
Thoughts?
I'm most likely not going to be much help here, for what's its worth. I had my rear 60FF narrowed and ends welded on, also bored out the spindles to except 1.5 shafts.for around $100-$AMC 150 at my local machine shop. The rest I did myself. I ordered alloy shafts and I cut them down to size. I installed the locker (spartan) and R&P.
The axle was free so I was into it for under $700.
Don't be afraid to use your local machine shop.
I've seen local pricing for complete 60's from $4500-10K, but everything here seems to cost a lot more.... I agree with Posi, try local shops first.
Appreciate the input, fellas
Have you looked into Ford 9".
  5.0%
