Bellhousing problem and oil leak
skinnerrouge
helper
Looks like a rear main.
Hi Brenda, no gasket needed on the bellhousing, the thin metal piece is just a dust cover. It may be the rear main seal on the engine leaking oil, so keep a eye on your oil level. You can pick up a Haynes or Chiltons manual for info and pictures on checking and changing oil in your Transmission & Transfer Case . :chug:
I was looking for this last nite but couldnt find it.:) Have to agree with Coldwater , looks to be a rear main seal. Not very hard to fix. Drain the oil , drop the pan , loosen the main cap , replace the seal , tighten cap to spec. , reinstall pan , add oil , and your done. Get yourself a Haynes manual or Chiltons and follow the instructions. One thing I found though is that you need to put a dab of silicone on each of the "feet" of the gasket for a leak free seal.
Ooops! I think I posted this in the wrong place
well there you go, A lot of the old engines have this problem. It really is a easy, if not time consuming project.
$35.00
  17.5%
