best alternator for plow
I've been plowing with my jeep for since the 1970's and at most all you will need is a dual battery setup with a 90 amp alternator off a Monte Carlo. They are just a plug and play improvement. No modifications necessary other to insure the plug is pointing in the right direction.
Plows usually only run for a few seconds at a time and the battery is usually all you need for the momentary current rushes. It's not like you are pulling on a winch for a long continuous time.
Now if you're running around 7k watts of light bar and semaphores worthy of some airport approach, maybe a big huge alternator is a good idea.
From the testing we have done all gel batteries will perform about the same with the exception of the Kinetik battery, lets put it this way, the drunken sailors in DC would say “wow that is an expensive battery”, however you get what you pay for.
Well I would guess the parts houses are going to hit you for $100 to $130 for a rebuilt, they probably will not know the difference between the two so you could probably give then your old one. The one I listed is the first generation CS144 its better than what you have but not the best. I would not go with it if you are going to be in the mud. As an unofficial site sponsor I can get the first gen to you for the site discount price of $140 normally $170 and I can do the second gen 140 amp for $185.00, normally $250.00
the second generation alternator is a much better design and it will handle the snow and mud much better plus it has 20 more amps. I would also recommend the adjustable external regulator. Dial down to 14 volts when not plowing to help with MPG and crank it up to 16 volts when you are plowing, this will make the plow work more efficiently, and you can do this from the drivers seat on the fly. This adds $40 to the total, keep in mind I bought the regulator at a special price, I have 11 left at that package price once they are gone it will go up to an additional $80.00 for the regulator. Both units I list here are 100% new.
Well lets back up, your post was “best alternator of plow” the $900 is the best, its what we install in the plow equipment at the ski resorts and we don’t hear back form them for 5 to 7 years. Now this option is quite possibly the best value, big difference. You could buy a F250 and if you are lucky you can find one with the dual alternator option, but if not you are in the same boat, the Ford has a higher amperage alternator but it also has more electrical load.
There is no such thing as a sealed alternator, there is elements resistance units that were designed for use in mining. We use them in desert racing and mud bog use, but there again you are back at $1K. Back in the day we built aluminum shield around the alternator on the CJ, will not solve the problem but it will dramatically reduce the effects. Been so long since we have built one I don’t even know if we have a templet but they are quite easy to make.
We have never rebuilt a Jeep gauge without seeing the melted internals around the indicators lights, the fact is lower voltage results in higher amperage, that creates heat. Higher voltage improves everything to a point, 12 volt batteries cant handle anything over 17 volts. Car makers shot for around 14 volts because the higher the voltage the more HP required to turn the alternator the less MPG.
No, I wouldn't, I like my eye's. I fly RC and I learned a lot about discharge rates vs. charge rates on the different battery types Nicads vs MiNH vs LiPO. There are no shortcuts here.This is one that is going in my blog, dual batteries work, that is a fact. Just like an artificial heart works, but it is not like the real thing. When you add 2 batteries you are splitting the load between the two. You have a larger voltage pool so everything looks more balanced. An alternator never “turns off” it only changes its output (duty cycle), it works like this. The set point is 14 volts and the system has 13 volts therefore I need to produce enough amps to feed the load and return the voltage to 14. With 2 batteries it will not give the alternator an accurate signal as to what is going on in the electrical system, due to the fact that it looks more balanced than it is. When you build a system like that you replace batteries faster and alternators faster because they do not work together as well as a single set up. So again I am going back to what is the best way to do it, not saying don’t run dual batteries, if you are on a budget it is a great way to go, just understand it is not the best way to do it. You are correct on wet charge rates but gel batteries are odd little things, they like a lot of amperage and voltage. You can take a red top that has sit for a year and is down to 1 volt or less, directly attach a good red top to the discharged red top and let is sit for an hour, then charge both batteries to 12.5 at rest volts. Many times you can save the dead red top, cant do that with a wet battery. BTW we play with volts for a living, don’t try this at home unless you know what you are doing.
One thing to keep in mind about the load is we are talking about max load, or the point at which the fuse will blow, volts and amps work in a teeter-todder effect, when amps go up voltage drops, this can have a cascading effect, the lower the voltage your system has the higher the amperage will be in the items you listed. I recommend using the fuses as a guide so that you will not have the alternator at full power all the time, and that will make the alternator last longer.
If it is electric it is a motor, it has an armature and field coil, there are many variations in how they look but they all basically work the same, and have the same power needs, newer units are more efficient.
Let me know if I have been more confusing that clarifying.
Now I have a bigger issue on my handsI just lost all oil pressure on my mechanical guage when driving to the carwash
Yikes
I have to start looking at it today with more snow on the supossably tomorrow..
I hope it's just a kinked hose.
