Best engine and transmission placement? Cj7 engine swap 4.3 v6
- Media
- 1
- california
- 1965 CJ-5 Buick V6 Ford T-18 4-Speed Spicer 20/18,Warn Overdrive Dana 30 & 44 w/Powr-Lok posi / both,4.27 gears 33" tires.
Hey Bent, Thanks for your help. Would you suggest drilling additional holes to move the engine further forward or does it look good in the picture as it sits?
I off-set the engine toward the right side just as it was originally. The only issue Im running into with the exhaust is the brake proportion valve hits into the driverside pipe... (Ill try to include pics..Sorry if they are sideways) My front driveshaft runs on the passenger side of the vehicle unless the exhaust will get in the way.... I will include pics soon.
Thanks for the pointers..![]()
76, I know your New at this and I applaud your drive to succeed ,
But as I have mentioned here before , you should "Never" drill holes or weld anything in place until all of the fitting for the motor , tranny , exhaust , drive lines etc. has taken place. This means from front to back and left to right........
Right now by locating your engine First , You have compromised all of the other components that also need space...........not to say that you may not be back to where you started at a later date, but without first taking these other components needs into account it will just make your job that much harder.
Swapping motors is all about compromise , in a world where a 1/4" will matter , you start by having the motor and Transmission hung in there via a hoist with jacks and blocking under it to get it level , then start adding things and making compromises.......
Change this or remove that , move this bracket over here.......Whatever
It may be your current exhaust manifolds have to be changed to a block hugger design to fit, it may be your engine needs to go fore or aft, I see you mentioned the proportion valve , if it's in the way move it, or an oil filter needs to be remote mounted , maybe a rear cross member needs to be moved .........the list is endless, but it can be done and as you move things around while visualizing and brainstorming for sometimes hours it will all finally start to come together where all the parts will best fit...........Don't box yourself in a corner , look at everything from start to finish so that you have a plan that can succeed.
And better pictures would surely be helpful.
