Broken lower Alternator Bracket
If you have the pieces, you can find somebody to TIG it for you. I am assuming the bracket is cast aluminum.
Works great to fix cast Al with a Tig welder. Grind the crack down and open it up a bit and weld it all back up. Has to be REALLY clean. Use IPA to get all the grease off. When you think it's clean, clean it again!
This won't be too expensive Dear! That's what I keep saying. Over and over again.
Thanks for the help folks...Appreciate the gestures of welding it. I'll just find a local machine shop and get it done.
