Broken lower Alternator Bracket
If you have the pieces, you can find somebody to TIG it for you. I am assuming the bracket is cast aluminum.
Works great to fix cast Al with a Tig welder. Grind the crack down and open it up a bit and weld it all back up. Has to be REALLY clean. Use IPA to get all the grease off. When you think it's clean, clean it again!
