broken speedo cable piece stuck in transmission
Big B
The new cable end would not go into the Transmission , so I am assuming this is the problem. There is nothing to grab on to with needle nose, etc. Any ideas ?
Thanks for the input everyone. I have tried soaking it with PB Blaster and using a magnet with no luck. I was trying to avoid opening up the t-case and removing the driveshaft because I am not a mechanic.
The tail housing and output shaft can be removed without removing the TCase. There are 5 bolts holding it on. The speedometer drive gear in in the middle of this assembly. To take it apart you need to remove the large nut holding on the U joint yoke. That nut is big and takes a lot of leverage to remove. I would remove it before removing the rest of the tail housing. Here's how I would do it: Drain the oil from the TCase. Remove the rear drive shaft. Put the jeep in 4WD low. Put the tranny in reverse. Remove the nut holding on the U joint yoke. Remove the five bolts holding on the tail housing. Once that is removed you can repair the speedometer gears.
Thanks for the replies everyone. A little more to it than simply "pull the gear out and fix it".
you still don't get it......
take it to a shop
