Changing out gears in a Manual Transmission
Shawn76
- Collinwood, TN
- 81 CJ7 Laredo with 258 straight 6, 3sp manual(which im pretty sure isn't factory) and not sure about transfer case. (Ive got to do some work on trans and trans case. It has a 4" SOA lift which was done correctly by someone. It runs down the highway at 65 as good as a new jeep.
Is it possible to change the 1st gear ratio in a 3speed manual Transmission ? I have a 81 CJ7 AMC 258 i6 / 4.2l with a 3 speed. It is great on the highway, but have to ride clutch a little too much when taking off. It may be in another thread but I can't find it if it is. Instead of doing a trans change out I thought I might just rebuild trans and replace 1st gear with a little lower ratio. Any help will be greatly appreciated!
